Best mobo for under 100??
For under 100$ would be the ASUS A7N8X w/ the nForce2 Ultra 400 chipset.. Im sure anyone else will agree its a very decent board. Here is a link
DFI Ultra Infinity, no question about it.
4 channels of SIIG SATA goodness, coaxial digital "soundstorm" input and output, onboard firewire (if you care), and absurdly high voltage options for just about everything under the sun.
Unless......you don't want to overclock? ;)
ive been drooling over the lan party board, mayyybee, just mayyyybee i will spring for that
but its little brother looks very very nice
its deffintely a top choice over the abit nf7?
They're both real good boards, the NF7-S (V2) is the one to compare with the Ultra Infinity since it's got SATA also. The DFI has double the SATA ports, digital audio input, onboard firewire, the main power connection point is a bit better placed, and it costs about six bucks less at newegg.
I don't think you can go wrong either way, but I'd take the DFI ;)
The LanParty B has Gigabit and 100Mbps Ethernet, a sweet glowey paint job, a shedload of accessories and an additional USB2 header. If that's worth $40 to you then it is :D
agree with that board.
so does the lan pary realy have any overclocking advantage or other performance advantage compared to the ultra infinity??
what all else does it have that is accualy usefull?
Is the DFI really better the the NF7-S? Does both boards get to 2.0 volts without modifications?
I'd have to say YES. Its the rare nf7-s rev 2.0 that gets over 225fsb stable whereas dfi owners are often hitting 230-250fsb. The DFI infinity allows for higher voltage increases in key areas and has double the sata ports. All those sata+ide ports would still be useful for a file server when you retire your mobo for something newer.
Not that I've seen, the BIOS options appear to be the same.
What...Gigabit ethernet, a tote strap for your minitower, a bunch of UV reactive cables, a weird front connector thing and UV reactive paint don't seem worth $40 to you? :D
the ultra infinity looks like it may have problems fitting some heat sinks, is there any list of ones that work with it and ones that dont?
I might build a computer around the DFI board, i noticed in the manual it likes 2.5V system memory. Does this mean any other voltage isnt supported? Does anyone have recomendations for ram?
2.5 Vdimm is just the standard for DDR, it's not what the board "likes" per se, it's just what the DDR stock voltage is supposed to be on normal DIMMs.
And yes, the Ultra Infinity supports overvolting the Vdimm (to 2.8V I believe), and the Vcore and I believe the Vchipset and the Vagp. It's an overclocking board :)
You might check the amdmb DFI forum, or you could e-mail AngryGames (DFI rep.) directly.
i personally havent had any experience with soyo boards. from reading this forum for a little while now i can tell you soyo isnt on the first tier of enthusiasts short list. dfi and abit nforce2 boards being on top of my current list.
When did the DFi fall to 100.00? Last I checked it was $145.00
But the NF7-S is only $100.00 and you can get the NF7 for a $75.00 w/o SATA & Sound Strom
