nwo4life022
- Mar 1, 2007
looking for a video card and wondering what is the best bang for buck in the mid range area at this time. thx
There is no 'mid-range' DX10 card thats worth buying.
There is no 'mid-range' DX10 card thats worth buying; The ATI 19xx cards that are cheaply available seem to be the best bargain right now.
My thoughts anyway. If you are going to spend 200+ on a 8600, eat kraft dinner for 2 weeks and buy the 8800GTS for 300 instead.
yeah um guys 8800GTS 320MB is by far the best midrange card its such a good deal for the money and it performs so much better than anything below it.
X1950XT blows 8600GTS out of the water:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102067
8600GTS is the best.
nösferatu;1031335759 said:holy hell, no one ever mentioned 2900xt in this thread anyway.
Because it isn't the best mid-range card.
yeah i have the middle drive cage out as i use the bottom cage for my 3 hard drives. guess ill monitor the temps when i get it setup and if its high i will add another fan. i have the 180b version with the 182 updates
"...if you are going to spend 200+ on a 8600, eat kraft dinner for 2 weeks and buy the 8800GTS for $300 instead.
I didn't say anyone did, but if you call the 320 midrange you have to call the 2900 low end, or at least low end of the midrangeAll 8800 series are high end.
You play games (8800GTS and up) or you don't (8500GT for 62$). Anything in between is just plain retarded.
