Best methods to clean my side window?
AY786
I have just finished painting my lian li case and the side pannel with the see through window (the acrylic) is very dusty and basically very unclean. Ive used water to clean this but its not 100%. Is there something i can use to make this clean again just like a glass window?
Windex
if a simple cleaning doesn't work, it may be marred or scratched, in which case a bottle of compound, commonly sold as Motorcycle Windshield Cleaner/Scratch Remover in any well stock auto parts store will remove stubborn dullness with enough work.
Try to blow off any dust particles you can first.
Then clean with Windex (whatever) in a dabbing motion with a clean soft cloth.
The idea being not to make long swipes or swirls which would create long scratches.
