best mega budget mobo/cpu combo?
Foz2001
What would be the best option on
http://www.tigerdirect.ca/applications/Category/category_tlc.asp?CatId=14
to buy a cpu and mobo combo...? TIght Budget of $150, im in Canada so CDN, I have everything else, the ram is DDR1 not DDR2 and the cpu cooler is for a socket 775 so keep that in mind. Its just for internet, word processing, etc. No gaming.
Thanks for any input.
Foz
edit: now that im looking further into it, it looks like most of the boards are DDR2.... hmm maybe ill look into the FS section
Do you have a vidcard? If so...
$80 - Intel Pentium Dual Core E2140 Socket LGA775, 1.60 GHz, 800 MHz FSB, 1MB L2 Cache, 65nm
$72 - Asrockk 4CoreDual-SATA2 Socket 775 Via PT880 Pro/PT880 Ultra Chipset, supports DDR1/DDR2, AGP 8x & PCI-E 16x (at 4x speed), 8-Ch Audio
AT Review: http://www.anandtech.com/showdoc.aspx?i=3024
Anandtech also did reviews on the board's older brother:
http://www.anandtech.com/mb/showdoc.aspx?i=2810
http://www.anandtech.com/showdoc.aspx?i=2813
http://www.anandtech.com/showdoc.aspx?i=2814
Summary: The board is a good, budget stopgap solution for people who want to get more life out of their DDR and AGP stuff. DDR400 is still fine for today's applications, and only high end (mainly NVIDIA; ATI scales better) graphics cards will be affected by the 4x speed of the 16x sized pci-e slot, but not by much (only 10% performance hit).
