Best mATX S775 board?
msbbc833
I want to upgrade my ECS PVT7050 motherboard that is based on the Nvidia 7100 Chipset. I'm currently running it with a E2200 @ 2.93 Ghz, however it bogs down sometimes under multitasking, such as when downloading from usenet, running antivirus, and unraring files. I want to keep my current case so I would need to get a mATX board. Also, Is it worth upgrading my CPU? Im thinking E5200 or spend $100 extra and get the Q9550. Input would be appreciated. Also, how much faster is a G31 or G41 chipset than the 7100?
Thanks
PS I forgot to add. I am currently running Vista x86 because my motherboard doesnt support x64. However would a new board work with Windows 7 x64? Would I see significant performance increases with 64bit? I run 4gb of ram and I dont think vista 32bit takes full advantage of it
If you have a microcenter nearby, you could always get the Q9550 and keep the current board if it supports the Q9550. I would go AM2
Why are the Phenom IIs so popular? I thought the Q9550 was roughly 10% faster..
Anything with more L2 cache will help if your mobo supports it. To directly answer your question, I love Gigabyte and ASUS both. If you want a Socket 775 motherboard upgrade, you can't go wrong with something like the P5QPL family or Gigabyte's EG41M boards.
But really for the $220 that Newegg wants for a Q9550, you can get an M3A76-CM or similarly-price motherboard and a Phenom II X4 810. That that $220 and add to it another $50 that you could probably get for selling your current mobo and CPU, and you're now at a Phenom II X4 955 black.
Add to that the fact that Socket 775 is only going to linger on as a budget platform from here on out (you're not going to be able to upgrade that board again if you went with a Quad) and the AM2+ platform will live on for quite a while as long as AM3 CPUs come backwards-compatible with DDR2.
