Best mail client across mutiple computers
nry
I have just bought my first mac (27" iMac) and love it!
Now I still have a windows laptop where my email lives at the moment.
What I would like is a mail client which I can run on both but they both remained synced.
I have a number of email boxes, and place all these emails into folders as I get them so these would need to sync across.
I am currently using outlook but could switch if the software is good enough, Im looking at getting a MacBook Pro shortly too so will all be running on Mac
Any suggestions on this?
Theres tons of info on the internet about it, but no what I would call perfect solutions!
I have been using GMail for this since 2004. Works the same on every computer I sit down at, as well as working on every internet-enabled mobile device I've ever used. If you want unprecedented consistency between platforms, use webmail, a shell email client, or some other remotely-hosted client.
If you must use a standalone mail client, you will find the Mac version of Outlook to basically what you are used to from the Windows version. There's also Thunderbird which is exactly the same on Windows, Mac and Linux.
What you want is a specific type of email account, not email program. An IMAP account, like iCloud, GMail,, Microsoft Exchange, etc stores everything on the server and you can make folders and etc and it will be synced every time the mail program on the computer you're at syncs with the server. If you setup multiple accounts on your mail program, you can view each account's folders individually or in one view, like each account's inbox will be displayed at once.
For the accounts you have right now, you can goto into the account settings in your mail program and you can view each account and see if it's connects over IMAP (good) or POP (bad).
Yep, just use imap. I log in to gmail via phone, web, desktop, whatever. It's all in sync.
Right will have a look into IMAP
Have used it before, but found it a bit slow
Does IMAP store a local copy of the email then once its synced?
Thanks all
Depends on what your client does, whether it's your phone or a mail program. Usually the answer is yes, if you're wondering about what will happen if your laptop is not on wifi.
Why not "Mail" - it does all the same things with gmail and is exchange, etc. compatible. Get "Mail" on all your devices and it'll be done.
