Best liquids for a closed loop?
JoeUser
Going to be putting my new loop together next week. Thing is that it's going in a SilverStone SG08 ITX case. Tight space.
So I'm making it a closed loop and am interested in what I need to add or not add to my water to make it last and stay clean. I want like LONG lasting...months!
For right now I've order some Tygon tubing and a anti-bacterial silver coil to put in the tubing. I will be using pure distilled water.
Any advice is appreciated!!!
I've never had any problems with Koolance coolant - and they even have a low conductivity coolant available should you want it (though it is less efficient at carrying heat)
Phobya ZuperZero Coolant. Best I've ever used. I've used clear tygon tubing and after a few months, the tubes would turn murky with distilled water and a silver coil. With this liquid it stayed nice and clear and has lasted me for about a year now.
Distilled water with a killcoil or pt nuke.
Back when aluminum radiators were common you needed to use a mix (or just add antifreeze) to prevent galvanic corrosion. Silver can also cause corrosion (particularly to nickle coatings). I'm not a fan of the silver killcoils, the one system I tried it in went murky.
I've been using CuSO4 (blue PT Nuke) and plain distilled water without issues for years.
I have always added a little antifreeze to be safe and even though I skipped having a reservoir altogether. Guess I just worried the barbs on the blocks would corrode over time.
