Best Liquid Cooling under $200
cyks
Opinions/facts please. I only wish to watercool my AMD X2 4200
Getcha a DD TDX/D5 combo, a BIX120, Fillport, some tubing, hose clamps and a T connector. Well under 200.
I sell 2x120mm rads for less then the BIX, MUCH less. I can also get you all of the tubing and clamps needed. I would also get a MAxijet pump/res.
what he said but get a BIP II instead.
I will just go with air cooling with a XP-120, because I don't understand anything most of you say. If someone really thinks I should go for water cooling over the XP-120, give me some links for what I should buy, it would be greatly appreciated.
if you dont understand it and arent willing to do a little searching to understand it, your best bet is to steer clear and go with the XP-120.
Well if no one can provide a link, why even bother to understand?
Everyone will have different opinions and acronyms, and I don't have the time to research them all. Maxjet is not on newegg, and the others are just a mess to read.
Edit: Mod may close this thread. Watercooling is just an expensive novelty anyway
if you read the sticky in the wc forum, you would see that much of the stuff can't be found on newegg but other onlines sites instead.
If you want a beginners WC kit and don't want to mix and match parts, Thermaltake has their Bigwater SE line that you can look into. Comes with everything and is well under $200 bones.
But then again if you don't have 'much time' than you're right, WC is a novelty for you and best bet is to stick to air cooling.
