I'm looking at building a new system from scratch, and it's looking like it'll likely be based around a 6850K. I'm not willing to go for water cooling, and though I briefly looked at sealed water loops the short pump life (3 years or so seemed about the norm) made them seem like they weren't worth the trouble. I do hope to OC the chip somewhat, but nothing crazy. If I can get it up to 4 GHz comfortably I'll be very pleased.
So now I'm looking for the best air cooling option. I'll be building this into a desk, so dimensions of the HSF only matter if they interfere with RAM or motherboard components. Vertical clearance is effectively not an issue. Part of the reason I'm building it all into a desk is dust control -- it'll have a large filtration element at the bottom and will likely feature several large fans venting air out the rear. As long as it doesn't scream like a production server under abuse, noise probably won't be a big deal -- it'll be somewhat dampened by the desk, after all, though I'd prefer something that does throttle fan speed based on temperature.
Price is a low consideration since this will probably be the only thing I use for the next 6-8 years.
If there's a self-contained water option that will last 5+ years reliably and has a very low risk of leakage, I'm also willing to entertain that.
Suggestions?
Suggestions?
