Best LCD HDTV For....
I need a new LCD TV for:
Upscaling DVD player via HDMI
Xbox 360 / PS3 via HD Component
Built in NTSC TV Tuner
PC inputs via VGA or DVI
My size range is 23" - 27" WideScreen.
Can you suggest something?
I have a 26" lcd HD tv
Sharp
Works quite nicely and has all the features you want.
wow thats damn sharp...
maybe i should skip buying a hdtv in a year or so, and this 19lcd monitor ive been checkin out, and go that route =]
What did you mount it to the wall with? How much weight does the mount support?
Looks very good btw
It's mounted using a Sanus extendable arm priced around $90. It's not the best quality mount, but i didn't want to spend a fortune. It's rated at 30lbs capacity and the TV weighs 28 lbs.
But engineers usually give you some headroom to cover their ass. I bet it could hold at least 40lbs.
