Best LCD 20 inch or larger
CompilerDude
Hello,
I am looking for a large LCD that I will use for programming and for gaming. A CRT is out of the question because a large one simply one fit on my desk. I am tossed up between the EIZO L885, Samsung 213t or the Dell 2001FP.
I dont really want to spend more than 2k on the monitor. Would anyone recommend one of the above three or would you recommend another monitor?
CompilerDude
See the HP L2335 thread. :D
23", 16ms, 1920x1200, HDTV compatible. 'Nuff said.
Im going to go with canislupy this one and say the 23" L2335. You say under 2k? You can pick one up for ~1500. You want it for programming and gaming? 1900x1200, thats an extra 300 pixels of space to put your code vs the others your looking at and games will look great widescreen.
Mine should be here next week :cool:
semiazas said:
Buy from where? Best price I can find is approx $1k.
gotta be patient and wait til they go on sale again at dell small business for 20 or 25% off.
if you call dell small business, theyll give you 20% off and free shipping, you jsut have to ask for it.
usually theyre 850 shipped.
ps: my vote is for 2x 2001FPs.
for 1700 bucks, youll have 3200x1200 resolution. they are fucking sweet LCDs.
You can get the Dell 2001FP for as low as $750 shipped from Dell's small business section during certain special deal periods. Typically you can get it for about $850.
They're very good monitors for the price (you can find reviews everywhere).
Check www.bensbargains.net a few times a week. They always post the deals on the 2001FP since it's such a hot buy.
Apple monitors are good if you don't mind paying the same amount a couple computers would cost.
Well the l2335 is the same screen with better inputs and pivotability. Unless you need the EXTREME color control that the apple firmware gives u there is no point in spending 300 more dollars.
Iv owned both the 2001fp and 213T and can say the following, especially as iv used TFTs for a while now.
The 213T without a doubt has better picture quality and the extra 1.3" actually is noticable, especially with the 1600x1200 res were dealing with here.
However there is a noticable difference in response time between the two, with the 213T being acceptable but definetly exhibits visible ghosting.
So its a matter of taste/needs to be honest.
I have also owned both and have had the same experience. The 2001fp went back and I kept the 213t.
The small amount of ghosting the 213t exhibits is a worthy tradeoff for the increased image quality. And I do spend at least an hour a day playing first person shooters, I barley notice the ghosting/blurring. Also, when reading text at 1600x1200 the extra size is helpful.
damn!
i bought the 2001fp, and i thought it was a huge step up in quality over my 191t.
is the 213t worth the extra 300ish bucks you think?
I haven't seen the quality of the picture on the 213t, so I can't compare that aspect.
But the Samsung will give you an extra inch, but the monitor also costs an additional $300-400 over the 2001FP depending on what deals you can get from Dell at the time.
I would have to agree and vote for (2) of something. I almost bought the HP, but I went with the Viewsonic VP201B. I really like it, but I haven't got to use it much yet :( If all is well after a week or so, I am ordering another one. You really can't go wrong with any of the choices that have been recommended. Good luck.
If you have a "$2K max figure" in mind----but are willing to bump it up another $300 then go for the new huge 24" black, sexy-looking Samsung 243T.
Same response speed as 213T and it pivots into Portrait mode if you want. Some owners swear by it for gaming as well as work.
Can you imagine the size of your 'coding' screen? You'll have a darn football field to code on !
Brilliant colors, 1920x1200, high contrast, height adjustable, sexy narrow bezel.
The 213T also Pivots
