KungFu-tse
- Sep 12, 2003
If money weren't an issue, who makes the best laptops?
Blasterboy460 said:IBM, but i cant afford it so im on an m6809
T42 has the dothan processors. i believe thats the biggest update (and the new mobo and whatnot to accomodate whatever intel changed). i forget all the detailsCSSmitty said:Speaking of IBM
what is the difference between the T41 and the T42 besides the Size (14.1" and 15")
noobie. lolSMPWorksForME said:ive owned two sonys two toshibas three ibms and an acre... Toshiba was the best with acer coming in as a close second. Toshiba has great support great gaming laptops great prices and great looks look at the satellite P25-S509 it has a 17inch widescreen and a great videocard... IBM's powersupply's tend to break same thing happened with my two ibms and my brothers and my dads and my teachers!!!! their powersupplies have to be propped up in acetain way to make the connecton.
artimasz said:it seems this fourm favors IBM to-the-max, however other forums favor Sager or Dell. It seems that it's [H] to own a IBM. I have wanted to try an ibook though.
emorphien said:T42 has the dothan processors. i believe thats the biggest update (and the new mobo and whatnot to accomodate whatever intel changed). i forget all the details
That and the 15" FlexviewTheGeneral said:Dothan and the introduction of the Mobility 9600
inc said:That and the 15" Flexview
onetrueday said:so, how's that acer from newegg line up?
I take it you know the centrino is the pentium M.primea said:If you really want a laptop ... go with a Pentium M, Centrino, or A64 mobile ... If I remember correctly, the one you linked up is more of a Desktop replacement, P4 3.0 GHZ will be murder on the battery ...
