Best keyboard under 25$?
madgun
I am looking for a USB keyboard with decent multimedia features. Which one is the most recommended under the 25$ range?
I had a Microsoft comfort curve 2000. It was fun to type on and it had low profile keys that made it very comfortable to use. I only stopped using it because my girl spilled a coke in it. It has spill resistant keys, but only if you clean it out rather quickly. So now I have Logitech's cordless desktop S510. Nice keyboard, but the keys are taking some getting use to. I hope this helps.
I would try taking it apart and getting the electronics out of it. Then stick the rest in the top rack of the dishwasher w/o any detergent. Let dry for a couple of days then reassemble. Has worked for me in the past.
Oh I fixed it. I just used it as an excuse to buy a new one. My girl will be using it on her new machine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109137
This is the one I use and I find it quite comfortable to use and it does have some decent media features. The zoom on the left side of the keyboard is nice if you using a high resolution and it's a little hard to read something on say IE you can zoom and it makes the whole page larger. The only downfall I can see is that after shipping it'll be slightly above your budget. It is a nice keyboard if you can get a little more into your budget.
Love the MS keyboard, feels so good.
