Hi All,
So it seems like my Plextor 716-AL no longer recognizes DVDs (see problem below). It's past its warranty, so it looks like I need a new burner. Blu-Ray isn't necessary, but Lightscribe would be kinda cool. Would just like something reliable, fast, good support, and very compatible. Need a regular ATA 3.5" internal drive (using an Asus A8N-E motherboard).
What would you recommend?
(Problem: When I put a DVD in, it tries to load, and I get a repeated 2 orange/amber blinks from the front light. When I click/double-click on the DVD drive in My Computer, nothing happens. Same goes for commercial DVDs and burned DVDs, any format. Yet it reads CDs and burned CDs fine. I've tried cleaning the lens and unit. I've tried to update the firmware and run PlexUTILITIES 1.3, but both say "no drive connected," even though the drive appears and "working fine" in the BIOS and the Device Manager).
