Best Intel HSF for overclocking?
defiant
Title says it all. I currently have an abit IC7 and 2.4C@3.0 on stock HSF. HSF im currently considering are the SP94, XP120, Aerocool HT-101or the gigabyte 3D Cooler Ultra GT.
All opinions or suggestions are appreciated :cool:
I'd take the XP-120. Better and quieter than a SP-94.
The Aerocool is not to my taste, I don't like those tower style heatsinks and the Gigabyte is only good at it's max levels which are pretty loud.
Considering how well the XP-120 cools with a slow spinning 120mm, it would be the best choice IMO.
either of those heatsinks should be good, but id go with the xp-120 because you can use a higher cfm, lower rpm fan, and i think its lighter than the sp94. also the zalman 7000cu should be good too.
I was thinkin the Xp120 but I havent seen any definitive reviews yet comparing it to the other heavy weight heatsinks, also there was that other fellow who was complaining that the sp94 was better....
