Best "inexpensive" 19" LCD
wtburnette
I just started going to LAN parties again and lugging my 22" CRT around is NOT going to happen again... :p
I'd like to get an inexpensive 19" LCD that will give me a good gaming experience and most of all, be lighter. I'd prefer not to spend more then $300, give or take. I'd prefer less, but I don't know what's feasible for a decent monitor. If it's not possible, I might just grab an old 17" CRT from work. At least that would be lighter then my monitor, which weighs a ton! ;)
How about the Samsung 915N for $295 after a $50 mail in rebate? I just got one and I really like it.
SAMSUNG 915N-Black
19"
8ms
300 cd/m2
700:1 Contrast Ratio
0.294mm Pixel Pitch
The only downside is that it is analog only, but I doubt you can get a reasonable LCD with DVI input for $300 or less.
Here is the link at Newegg
I'll have to look at all of these to see what I think. Any others I should be looking at?
Well, I just ordered the 940B. Hopefully it'll do the trick. Thanks for all the responses... :D
