best hsf fo 939
If you already know about the XP-90 and XP-120 then why are you looking for something else? The XP-90 and a good 92mm fan is the BEST option for aircooling.
There are other K8 solutions like the Thermaltake K8 Silent Boost and Venus 12 that cool good but they aren't the best.
There is always the Swiftech MCX6400V and the new Zalman CNPS7700-Cu
The Thermalright XP-120 with a SilenX 120mm 14dBA Fan is the best possible air cooling and no noise. ;)
Get the fan here.
http://www.silenx.com/ProductCart/pc/configurePrdz.asp?idcategory=3&idproduct=76
Specifications:
Fan Dimensions: 120 x 120 x 25mm
Fan Input: 12V/1.2W
Fan Speed: 1600 RPM
Air Flow: 58 CFM
Noise Level: 14 dBA
Three Pin Connector
Four Pin Connector
$24
If your not one to whine and bitch about noise and want to beat water cooling using the XP-120 then get the Y's tech 120mm fan that puts out 120cfm @55db and know you have the best air cooling and noise to go with it! :p
Zalman CNPS7000-Cu
I have one, 2.25 ghz, 1.550 volts on a 3000+ s939, 32c under load, in a praetorian
