sanosuke2999
- Oct 8, 2004
I was wondering if you guys could point me to the best 120mm fan in your opinion. I need it for a zalman dual pipe vga cooler. I looked at the optional zalman fan, but you really can't evenly cool off the huge heatsink with just an 80mm fan. So I figured a 120mm fan would do a much better job at evenly cooling the card. I am running a x800 vivo soft modded to xt pe. Also I am not concerned about the noise level at all, as long as I get raw power
