We used to use Heat but have moved to Frontrange's ITSM.
I'm just wondering if there was any reasoning behind not going with other ticketing system programs? Or, what made you choose ITSM over others?
Thanks
Exchange and Outlook work fine for us ;-)
Best ROI out there!
Just for the sake of the thread.
I spent a lot of time reviewing helpdesk products over about 3 months and eventually went with Parature. Really when it came down to cost, their sales team was willing to match/beat any of the competition. It's worked extremely well for us (1000 user base spread across 20 US offices).
I use atlassian jira as an issue tracking system. I manage the IT dept of a software development company with a large hosting infrastructure, so we have a ton of spill over. it works well enough for issue tracking, not only bug traffic, but I find that reporting is a bit unwieldy.
We set up different projects as queues (helpdesk, project related issues, etc, etc) and it seems to work well.
I can answer any specific questions you may have if you'd like, but I sort of don't know where to start...
I'm back now, we've been planning/designing/structuring JIRA 4.0.1 for use as a ticketing system. It really comes down to JIRA sucks if you desire any functionality. It's simple, this program is not meant to be a ticketing system by any means.
So I'm back to square one, what is the "best bang for the buck" ticketing system around?
JIRA = Out
Request Tracker = Out
Numera is too expensive(well from what my boss says anyway!)
Checked out Parature and ten minutes into the live demo, I was falling asleep
What functionality are you looking for? We have 10s of thousands of tickets in a JIRA setup at my employer, JIRA has been really customizable and responsive. Have you called up Atlassian and asked for help?
Here's a extensive list of some pretty serious issues I've came across regarding JIRA functionality, or lack of.Our JIRA would need to go big compared to most smaller organizations. Our current ticketing system has over 500,000 tickets/issues/requests in it. We assume our new one could have that after 4-6 years time. My personal worry is that JIRA doesn't scale well when it gets big. Java is also not the code to go with if you want to keep your memory threshold low.
http://forums.atlassian.com/thread.jspa?threadID=38958&tstart=45
http://jira.atlassian.com/browse/JRA-11125
http://jira.atlassian.com/browse/JRA-9
http://jira.atlassian.com/browse/JRA-3821
http://jira.atlassian.com/browse/JRA-1330 (Field level security which they said they won't ever do)
http://jira.atlassian.com/browse/JRA-1549
http://jira.atlassian.com/browse/JRA-6381
http://jira.atlassian.com/browse/JRA-5865
http://jira.atlassian.com/browse/JRA-2983
http://jira.atlassian.com/browse/JRA-8874
http://jira.atlassian.com/browse/JRA-2220 (amazingly, you cannot inactivate a user in JIRA - a pretty basic design in database/user management. This means your user admin will not be sending you any Christmas presents)
http://jira.atlassian.com/browse/JRA-1688 (User mgmt permission)
http://jira.atlassian.com/browse/JRA-1655
http://jira.atlassian.com/browse/JRA-5959
http://jira.atlassian.com/browse/JRA-9091
http://jira.atlassian.com/browse/JRA-6146 (there is no issue locking! For large installations, this could be a dealbreaker)
http://jira.atlassian.com/browse/JRA-7211
http://jira.atlassian.com/browse/JRA-11990
http://jira.atlassian.com/browse/JRA-11165
http://jira.atlassian.com/browse/JRA-8689 (This is a necessity for helpdesk users - to lock down their ability to mess themselves up)
http://jira.atlassian.com/browse/JRA-12650 (imperative if using email as issue creation tool)
http://jira.atlassian.com/browse/JRA-5509 (necessary if you want more than 1 user account per client)
http://jira.atlassian.com/browse/JRA-12306
I just want to note that making this work the way we need it to must be done as a plug-in, if you write directly into the core code, it will break during an upgrade. I guess I'm just pointing out that you're kinda doing their work for them with this. I also want to point out that the latest version of JIRA has more eye candy but none of the major issues have been fixed that are more then 3-5 years old. The company does not seem to have their priorities in order.We use JIRA. Love it. We used to use a Lotus Notes based system (still use it for customer issues) but had all sorts of replication issues. We have offices around the world that all hit one server so there's no sync issues. We've put a few custom workflows in place for various projects that don't follow the "standard" workflow provided. If you've got folks that can code in Java you can make it do anything you need it to do.
Will check it out, what's there to lose. By the way, what did think of JIRA? And why would you stop using Footprints + Track-It, I thought that was the best ticketing system?The school I work has is using a program called Sys-Aid, from a company called Ilient. Having used Footprints, JIRA, Track-It, and a couple of others- this was an awesome choice for us.
The problem doesn't seem to appear until JIRA gets populated with 200,000-350,000 tickets/issues/requests, 50-100 projects, thousands of users in the DB(not active), lots of heavy dashboards, etc.
Do you know what hardware you're running your instance on?
How often do you reindex? Do you utilize a heavy GUI based dashboard? How active users(logged in and working) do have? We plan on having 175-225 constant users.
how about this ? I just ran across this looking through all the options for windows web app installer.
http://www.microsoft.com/web/gallery/nservice.aspx
I was going to try to use this before the boss decided he wanted to spend 10k on a crappy BMC Service Desk Express. POS. Interface is slow and clunky and not very intuitive at all.
nService installs easy with MS Web Platform Installer. Easiest thing since sliced bread
