Geeky1 said:Actually, there are a number of heatsinks that outperform the SP-94; the CoolerMaster Hyper6 and the Thermaltake Tower 112 being two of them.
saturnine2 said:The Thermalright SP-94 can only accept 80 and 92mm fans. I'm not aware of any heatsinks out that can accept 120mm fans. 120mm fans would be a waste on most heatsinks due to the large "dead area" in the center of the fan that puts out little to no airflow. The larger a fan gets, the larger the dead area, and the dead area is usually right over the cpu. You can find a lot of heatsinks, fans, and info at frozencpu.com, crazypc.com, svc.com, etc.
Yep Al=Aluminum, Cu=Copper, AlCu= Aluminum+Copper. There is very little difference between the 100% copper and the copper/Aluminum hybrid.PhattyT said:is the Zalman CNPS7000A-AlCu made of copper and aluminum?
