Best HDD for $50-75?
gamerx11
Was looking into getting another HDD for my computer b/c im close to full on my main one. I needed another for mostly just data storage like videos, music, and d/l'd games. Any sugggestions?
How much capacity do you need? The Samsung HD502HJ 500GB is single-platter, fast and quiet. I've bought 3 500GB WD Caviar Blue 500GB from tigerdirect the last few months and all were single platter as well. Western Digital and Samsung are the only HD makers I'd buy from. Seagate has been very very very unreliable now.
With less platters, you get more reliability, speed and quiet. There's the WD black series with more cache. However as far as I know none of the black series are single platter, and I think the extra cache isn't worth the price premium unless you need more than 500GB.
samsung f3 series +1
i'm using the 500gb hitachi 7k1000.c, also 500gb platter. those are the only two hdds i'd recommend, and they both sit around 55usd.
samsung or hitachi - best hdds, period. (imo)
If your just using them for storage, I would recommend getting a Western Digital Green drive, there often promo's on the drive that have the 1TB model going for about ~$70.
The Samsung F3 seems to have one of the best track records for reliability atm compared to the WD Green and Black series.
Keep an eye on NewEgg and you should be able to snag a Samsung F3 1tb for your target price range within 2 weeks.
I buy whatever is cheap, but if I need something for a hot environment I favor any green drive (5400-5900 RPM) or 7200 RPM Hitachi 7Kxxxx.C (may also be called HD3xxxx) because the latter may be the lowest power 7200 RPM drives available and can be configured to slow down to idle at 4500 RPM.
For older equipment that doesn't like 300Gbytes/sec, get a WD or Seagate because they can be made compatible through jumpers.
If you don't like idiotic tech support, avoid Samsung.
