Best HD tray system
notsane
Looking for something to use in the upper area of my P-182. I have three 5.25" bays available. I would like something with SATA power and would like simple wiring on the back of the tray (just SATA and SATA power if possible). I am thinking that a 4 drive system that fits in three 5.25" bays would be best. I would like to get good quality and am not afraid to pay for it (within reason). I have not had much luck looking at products at newegg because I can't really tell what brands are quality from the pics. Even a brand recommendation would be helpful. Thanks!
Here is my temp solution, taking the upper drive enclosure from my p-182 and sticking it into the upper compartment.. Less than ideal, but lower areas of case are blocked with video cards and a huge power supply.
