Best hardware for editting and encoding?
blade52x
Current system specs:
  • 8086k at 5.2ghz
  • 64gb DDR4 at 3.6ghz
  • 3TB NVMe SSD active storage
Amazing for gaming, but trying to edit and then encode 8K video in Adobe Premiere Pro CC is painfully slow.
Video file sizes:
  • 7680 × 4320 at 60fps
  • 7680 × 7680 (3D) at 30fps
If I don't edit the video, encoding by itself isn't too bad right now. It's maybe 10 minutes of processing per minute of video. But once I start adding things like color adjustments, or a denoiser, the processing time jumps significantly to on the order of a day for a 10 minute video.
I'm pretty new to video editing and encoding and am wondering if I need something more workstation grade, or maybe even dual socket to reduce these times?
The fastest cpu for encoding I think is an i9-7960X followed by the Threadripper 2990WX. Not cheap thou lol
Reactions: Dan_D
Yup. And you'd probably want to stick with Intel if you're going to use Premier.
I'm going to suggest something different: try Davinci Resolve, and try running it on Linux, which you can do from a USB stick. Also share your GPU setup.
Davinci relies heavily on graphics cards rather than processors. It’s nice. Adobe premiere uses a fair bit of grunt, what suits you better depends on your workload..
