wait for the revision 2 of the NV5 before you even consider takeing the chance with one of theseretardedchicken said:i would suggest a 6800gt along with a an NV silencer5 for it, it will lower case temps and GPU temps by 10c, which allowed me to clock my 6800gt (from Evga) to 421mhz/1.14ghz stable.
Ballz2TheWallz said:if you want a little bit easyier on the pocket,6600GT works well too
http://www.hardforum.com/showthread.php?t=854977SlasherDNA said:NVSilencer 5 rev.2 is coming?? w00t?! Is this true? What will be the difference from "rev.1" ?
TGO said:I'm getting water cooling so i should be able to keep the temps resonable. Any specific brand of 6800s and x800s that are better for ocing?
Damn, havent noticed that, tnx!Ballz2TheWallz said:
