What's the best fanless, single slot card I could buy that is no taller than a PCI slot? I was looking at the Sapphire 6670, but it seems to have a radiator that extends up and above the board and I don't have that kind of room in the case. I don't care if it's nVidia or ATI flavor as long as it works in an AMD board. Advice?
edit: Based on a search, I figure I should supply the following info when asking:
PSU: 560 watt Seasonic
CPU: Athlon X2 Regor at 3 GHz
RAM: 4 GB
Resolution: 1920x1080
Max budget: $50-100
Case: nMediaPC 5000B
Purpose: Output from HD capture card, playing raw .M2TS video at 1080p60, making Windows Media Center not lag when playing video from capture card, in general speeding up the PC. Possibly some light video editing using the Windows Live movie editor.
RAM: 4 GB
Max budget: $50-100
