Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Im looking for the best fan in the $40-$50 range (cheaper=better )
Im looking to OC my i7 920 to around 3.2-3.4 and keep it on for 24/7 and once in while oc to 3.6-3.8 and use it for a few hours thanks!
Coolermaster V8 could be in that range, or Xigmatek 1283 Dark Knight... or a bit more and get a TRUE 1366 which is generally considered the best if not in the top 3 of air-coolers, and the 1366 kit comes with a good fan and fan bracket, mounting kit for ~$65-70.
