Best Fan Controller?
liquidfluidity
I'm needing a fan controller for my Alienware case and I want to use my 3.5" slot. I would like to know which is best. I will probably have 3-5 fans in use - intakes , exhaust , and harddrive coolers. Please include a link if you can. Thanks!
Ok , I changed my mind. If there is a controller that happens to be in the 5.25" range and it is substantially better than a 3.5" model , I'm willing to go that direction also.
I don't know which are the best, but since you said 3.5 inches, I know Vantec makes some. case-mod.com sells them.
Thanks for replying guys. Any idea how far that knob sticks out on the Zalman? I have an Alienware case and it has a door which I need to be able to shut it yet.
if that was a issue couldnt you push it a little further into the 5.25 slot?
