Best Fan controlers!
thezfunk
I just installed some fans that turned out to be quite cool yet very loud! Who makes the best or some of the best bay controllers that I can hook the fans up to and control them from the front?
Well, I'm really starting to like the new fan controller that I picked up from SVC... It's made by Sunbeam and the really cool thing about it is that it adjusts from 0v to 12v and can handle 20w per channel! I love that I can actually shut fans off with this thing. (They're only $14.99, too!)
Anyway, here's some linkage to the two different versions of it (one is black and the other is silver):
Silver
Black
My fancontroller handles 24 Watts per channel. Skycable. aka THE stuff.
I do need 6 fan control or can i piggy back more than one fan on a channel?
Silver
Black
That fan controller sounds great. Just wondering, lately I've been hearing people say that on low settings that the fan controllers buzz. Does this happen with your controller?
i wanted to get a fan controller to crank the rpm's up on my fan when gaming, but put them down real low (or even off) when im sleeping (my pc is about 1ft away from my bed, and all those fans make a lot of noise). idealy i want one that will use the lowest possible rpm's, but if the temps raise will raise them up automatically (it gets really hot in my room). here's a few questions:
1. some of my fans use molex connectors and some use the 3 pin connector, would they all work?
2. i currently have six case fans. do they make controllers for more than 4 fans?
3. about 2 of my fans are antec, and the rest came wit my case, will all of them work, or are the fans supposed to have certain features, like thermal sensing?
i was thinking about getting this one even though it's only for 4 channels:
http://www.newegg.com/app/viewProductDesc.asp?description=13-999-216&depa=0
if anyone has a better recommendation that will suit my needs plz post.
thanks!!
