Best Fan Control Software
BradF1979
So my card has decided that it's going to ignore the fan that's setup in the BIOS. So I'm curious as to what the best software is for managing the fan. I've got HIS iTurbo downloaded, and I also tried Sapphire TRIXX (which is actually the exact same program as iTurbo, and probably MSI Afterburner).
I downloaded ATI Tray Tools but it gave me an error after install (x64 W7), and Speed Fan doesn't seem very intuitive....
I don't mind using iTurbo, but it takes up 50MB of RAM which seems absurd...
I wouldn't mind using CCC but it seems you have to set a constant fan speed, and I want it to be temperature controlled....
Thanks in advance for any advice....
MSI Afterburner has the feature built in.
attachment.php
or edit the bios.
I've already tried this. It does not work. My card is not responding to the BIOS fan control settings, even the stock BIOS. There is a sensor busted on the card most likely.
Yes, thank you so much. It's great. And it only takes up 5MB of RAM. Sapphire and HIS take up 50MB. Thank you!
