Hi,
I need some help here, I'm building a box for my car's amp to prevent it to get damage by things in the trunk and also to save some space. The amp is air cooled, so I need to make the box well ventilated.
The fans will be on each side of the box to make some kind of a cooling tunnel, though about putting 3 120mm per sides. But now I'm wondering what would work best a pull/push, pull/pull or a push/push setup. Or even if i should only use fans on one side and keep the other side just open...
So what's your opinion? I'm building it today so i'd like to get a quick feedback!
Thanks!
Thanks!
