To run two client.
Set up a second folding directory, the easy way is to just copy the first and change its name.
If you do copy a directory, then you need to delete the work folder, the Queue.dat file and the Client.cfg file.
When you start the second copy up and config it, make sure you change the MachineID to 2 otherwise it wont work.
Luck ...........
