I'm trying to decide on drives, and have been doing a lot of Googling. Unfortunately, no drive seems to meet all the recommendations people are making. Specifically, don't use drives with TLER, and insist on 10^15 URE.
Option 1: WD Red drives
Pros: Cheap
Cons: TLER isn't recommended for ZFS (not needed for ZFS, but some say it could actually be detrimental), URE rate of 1:10^14, which is considered low/risky
Option 2: WD Se (low end enterprise) drives
Pros: URE rate of 10^15
Cons: Expensive, still has TLER
Option 3: Desktop drives (ie. WD Black, Hitachi, Seagate)
Pros: Cheap, no TLER
Cons: URE rate of 10^14
- Will RAIDZ2 protect me from a URE, should one occur? (ie. Can I buy URE^14 drives and sleep at night)
- Can TLER be turned off easily if I buy drives with it, and is it necessary to do so, or should I not care?
- What drives do people run successfully with RAIDZ?
(Not looking for backup advice.)
Thanks for any thoughts.
Pros: Cheap
