Hello all...
... I have 2-100gb Sata drives that I have setup with Raid 0 right now with xp2. What is the best configuration (as far as performance goes) to set these drives up for gaming and video encoding? I've read that two separate drives - 1st for OS and the 2nd for data is a good way to go. Does this mean all programs would be installed on the 1st and games/data would be installed on the 2nd? And when encoding the original file on 1st and the encode on the 2nd?
Am I on the right track here or is my current Raid array or possibly a striped volume a more efficient setup?
Should I be concerned with partitions at all?
Also, when reformatting, does changing the allocation unit size have any effect or should it just be left at default?
Thanks.....RpM
Thanks.....RpM
