peacetilence
- Sep 23, 2004
What are the best dremel discs for cutting aluminum case material
Not really. They are made for cutting tile & ceramics mostly. Once the abrasive wears off you have a nice useless metal disk.Anyone have the Diamond coated discs? how are they for metal? Does it last longer then the reinforced disks?
www.widgetsupply.com has a good selection IMO. Fiber reinforced cutoff wheels are ~17 for 100. I've seen them cheaper, but they have other stuff as well link
