Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What dremel cutting blade would you recommend for cutting aluminum(sp?). I have a old Lian-Li 60 case that is gonna get a face lift. And I was just wondering what the best bit would be that won't break and kill me
I always liked the fiberglass abrasive cutting disks, though they can produce a pretty messy cut if you arent careful, so you'd want to cut a bit inside the lines, and file/grind the rest out.
I've never tried the metal, diamond tipped blades, but I imagine they'd probably work fine, though heat would likely be a problem.
If you are doing something like a window, then a jigsaw is probably going to give you the best results, if for no better reason than it is a lot faster...Draw the cut, jigsaw it out (within the lines) and then use an angle grider or a dremel grinder bit to smooth it out. You can get a decent, cheap angle grinder for like $10 - $20 at a place like harbor freight
To start I'm gonna cut out a large section of the side that looks like a double headed eagle. I.E. if you've ever played warhammer 40k you'll know what I'm aiming for.
