Best drain system (while minimizing flow disruption)
Kharz
Hey guys -
I am on WC build #2; the first one was the original Swiftech Apex kit (love the storm water block) and now I am building my second box. I am using the L5 pump, Voyeurmod quad heatercore and a radiator. However, a lesson from my first build -- I want to build in a drain system.
My best thought now is to add in a T-line at the bottom of the case with a DD fillport in it. To drain I would remove the cap from the reservoir and then drain away. However, I hate that all the barbs I can find online are plastic and was curious if people had better ways to drain the system?
I do realize there will be some flow disruption to this WC set-up; however I really dislike having my current loop w/o a drain.
Any and all advice is welcomed, thanks!
-Kharz
**edit**
Minor spelling adjustments ;-)
Yeah, I use a 5/8" to 1/2" Tline (5/8" in the main part of the loop so I actually DECREASE flow resistance) at the bottom of my case. I attached to that 2" of tubing and a brass ball valve found at home depot. Total cost 6$.
I agree, non-metallic hose hardware sucks, the brass stuff is really nice and sturdy.
i would love to see pics. and everytime ive gone to the hardware store, they dont know what "bleed valvE" or "ball valve" means. sigh.
I've got a 1/2" ID t-line and a delrin fillport that I use as a drain. It's a real bitch to get the tubing on the oversied 't', but it shouldn't restrict flow.
What's wrong with plastic fittings?
Hardware store employees that don't know what a ball valve looks like? Wow, that is sad.
Anyway to spot a ball valve look into the valve housing through one of the pipe fitting ends. Then turn the handle, if you spot what looks like a ball with a hole right through the middle then you found one. Another way to easily spot one is to look at the handle itself. Usually a ball valve will just have a straight handle that is only a quarter turn from stop to stop. A gate valve has a circular handle that is most often associated with valves (think any valve handle in Half Life).
