Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I just bought a brand new DP 1.4 cable off Amazon. Brand is Accell. My new LG 34GK950F will be arriving this week, so I bought a new cable in advance to take advantage of the DP 1.4 ports.
The Accell cable I bought was $20, is 2m in length, and has non-mini male to male connectors. Well worth the price IMO. I currently use an Accell DP 1.2 cable, and have never had any issues. I think they’re one of VESA’s main certified vendors.
As the previous poster suggested, I checked the VESA recommended products page. I wound up buying a Club3D model CAC2068; DP-DP, 2 meter, 1.4, HBR3. That last part of the spec was my focus as IIRC it allows for uncompressed ( no Display Stream Compression ) 10-bit 4:4:4 UHD @ =/> 60HZ data rates. I too will be connecting a Quadro (P2000) to a BenQ SW320, alas I have not completed my new build so I have nothing to report about product satisfaction. When I researched the brand I found nothing pro/con. But then I didn't find recommendations for the competition either. The cable cost $16.20 including tax with Amazon Prime. Keep us informed on your choice and satisfaction.
Use only certified cables if you care about using near max bandwidth and not having random blankouts.
I have had no problems with quite a few accel cables now for DP 1.4 required resolutions and refresh rates, after having to replace a number of random cables that came bundled with the same monitors. Grinds my gears they try to save 20 cents on a cable with a 1k monitor, bet their bean counters didn't check how many RMAs might be saved if the fucking cable worked properly.
Also keep in mind no matter the cable, interference is still a thing. I have some cell phones and other stuff that will cause issues when they get close or if many data cables get coiled together.
For some reason USB is a typical offender for me, it shits all over my QSFP DACs (copper 40/56Gbs) especially hard.
