xdkimx said:i personally use o&o defrag http://www.oo-software.com/en/products/oodefrag/pro.html but diskeeper should be just as good
heres the free edition http://www.majorgeeks.com/O&O_Defrag_2000_Freeware_Edition_d4545.html
serbiaNem said:I'm using O&O for the time being until Perfectdisk releases a version for x64. It's kind of a system hog (40mb background service 24/7), but it works.
dirtydr said:imho, that would be diskeeper.
fast is a relative term though. if your disk is extremely fragmented its going to take time to defrag it no matter what app you use![]()
tdg said:I just bought Diskeeper 9 last week and I like it a lot, it's quick and defrags very well, much better than the older versions. I was previously using O&O and have PerfectDisk on my laptop, but Diskeeper seems to be doing a better job than both for me.
mikeblas said:How are you measuring the results?
Yeah; O+O has a few different modes. If you don't take the time to learn it, you might find that you've run it for speed instead of completeness. Meanwhile, the fragmentation you noticed might have been caused by another task writing to the volume while fragmentation was running, or after it had just finished.tdg said:Defragged with O&O and when it was finished, there was still a bit of fragmentation so I just decided to purchase and download Diskeeper right then, and defragged right away and it consolidated the data quite a bit better![]()
