Best deal I've ever gotten
LeftSide
Just got a Dell/Sony Trinitron p1110 21inch crt for $25 at an auction! I was using an old Gateway that was loesing its color, All I have to say is WOW. This monitor looks better than any lcd I have ever seen. The Colors are amazing.
My friend bought one too, but the blacks are coming out gray. All the colors look good, it just looks gray whenever there is a black background. I was wondering if anyone here has any good monitor setup references, or some advice on how he could get a better picture...
The P1110 model has a common problem with the brightness gradualy increasing over time :( this causes it to become washed out (Black turns grey) ..You can try running the Image Restoration option and see if it helps ..otherwise you'll have to replace a certain capacitor inside.
More info here:
http://www.hutzelman.com/home/hardware/mods/monitor/
Sony Monitor Brightness Fix
Many Sony Trinitron-based monitors manufactured around the 1999-2000 time frame develop a brightness problem over time which substantially degrades the picture quality. Some models which exhibit this problem are the Sony G500 and the Dell P1110. The following "fix" has helped me and many others get the brightness and color back to near factory specs. The main signs that you have this problem will be the absence of a good black level - even with the brightness set to 0, the monitor will show blacks as bright greys. [Disclaimer: this "fix" is not really the correct way to fix the problem, but the results should be quite satisfactory.]
