Best DDR2 800 sticks
AJaxx.
What would the gurus over here at [H] recommend I get for my two 1gb sticks that are DDR2 800. I want the best there is. Thanks.
anything micron based really.. i'll be getting in a pair of crucial ballistix soon that i have good expectations of :D
Micron's new die is awesome for DDR2 stuff, that much is true, but you would not believe how tight the screen is for the 6400C3 sticks. We screen a buttload (memory industry term) of ICs to get enough for a single pair of 6400C3s.
Luckily, the ones that don't do 6400C3 can usually do 6400C4 or 8500C5...heh.
yeah, i'd believe it. i just picked up a stick of crucial value.. for some reason crucial's value ram always does well for me, got it up to 558mhz at 5-5-3.. 3-3-3 tops out at around 300mhz without cranking the voltage
