Best current Ultrawide 1440 options?
Colonel Sanders
I'm looking at finally upgrading my Acer XB271 (27" 165hz IPS) with a curved ultrawide. Needs to have VRR (Gsync preferred but FreeSync should be fine) at least 120hz and VESA mount compatible. 1440 vertical rez is ideal but if there's a higher rez one that ticks all the other boxes that should be cool too.
I'm also interested in one that's bigger than 34" i.e. has a TALLER as well as wider size than my current monitor (I believe ultrawides listed as 34" are the same height as a 27" 16:9 display) but if no options exist, especially for a halfway sane price, than 34" should be fine.
Thanks in advance for any tips you guys might have!
You are correct. A 34" 3440x1440 monitor is the same height as a 27" 16:9 2560x1440 display. From 34", the next size up is generally a 38". The cost also goes up considerably from there. Alienware's AW3420DW should fit the bill quite nicely for what you are looking for. Alienware also has a AW3821DW, but as expected, the price goes up as it's a 38". You virtually double the cost between the two models. It is 38" and goes to 3820x1600 in resolution. It still maintains the 120Hz refresh rate and both have G-Sync compatibility. Acer and ASUS also should have similar offerings, but I know a lot less about those.
I've had the AW3420DW mounted on a dual monitor arm with a Dell S2716DG for 20 months or so now and it's been great. I'd recommend one if you can pick it up for a good price.
not a ultrawide but so much better than my 27". I got the Samsung 32" G7 and I just love it so much. I love the curve and the extra vertical height of the 32"
I personally stayed away form ultrawides because I wanted more vertical height than a 27".
I actually liked this monitor so much I bought a 2nd 32" for dual screen.
Just an idea to just get the 1440p 32" G7 instead of an ultrawide.
thanks. it's not a bad idea actually, i'm also considering triple 16:9 monitors as i do sim racing and flight sims and such too
Triple 32" curved G7's would look awesome for sim racing, but you would have to have a good video card to handle 3 1440p monitors.
One thing with the G7 is some don't like the curve, I actually like the curve a lot and why I bought a 2nd one, amongst everything else I like about the monitor. While it will look odd for the first half hour it becomes normal and it makes games much more immersive.
If you are not sure I would recommend you buy just one monitor first before the others.
