I am thinking of getting SLI, and its a bit cheaper now than what I budgeted so I figured, I get a another card for PhysX only, whats the best GPU to get for dedicated PhysX? Does it max out a 9800 GTX? or a 250 GTS? etc? Should I use a 260 for PhysX or no point? And if so, do you think the next version of PhysX will max out and need a 260? etc?
Cheaper the better
ps. I need something with a water block readily available. 9800 GTX looks like a winner.
Cheaper the better
