currently the best bang for the buck is the gtx 275.. but look around this section of the forum.. theres about 10-15 different threads talking about which cards are the best price to performance..
All of my rigs are having some sort of problem right now..
Yes, it is the shader count. The GTX275 has the same number of shaders as the more expensive GTX280, so although it has less memory and a narrower memory bus, it is just as good for folding due to the shaders. It is also a newer 55nm GPU, so it can reach higher clock speeds than the older GTX260s and the GTX280. Considering the fairly low price, those factors make it an ideal folding card, especially based on bang for the buck.What are the reasons everyone seems to favor the GTX275 over the GTX260. Is it the shader count, GTX275 = 240 and the GTX260 is either 192 or 216.![]()
The main problem with the GX2 is availability. It's basically impossible to find a new 9800GX2 these days. Another issue is power consumption; it's two GPUs, so it eats up a pretty hefty amount. The GTX275 puts out a bit less PPD, but has much lower power consumption.What about the "king" of GPU2 folders, the infamous 9800GX2. Even under water are they still hard to keep cool (like less than 65c's)![]()
Yes, the GTS250 only has 128 shaders, so it isn't nearly as good a folding card as the GTX275. The GTX275 also has better PPD/Watt performance.What about the GTS250 (I know a rebranded 9800GTX or 9800GTX plus) AFAIK it uses only one 6 pin vs 2x 6 pin connecters of the 9800GTX series, but it only has 128 SP's (I think)
I've been wondering why 275 > 260 also. Is seems to me a 275 is 10% or so better for 50% more $. Seems that a 260-216 is the best choice.
