Best CRT for under $125
HOCP4ME
Well, today I really stressed my 3 year old CRT, played MOH for about 5 hours. Then I left the room for a few hours without turning the monitor off. When I came back, the picture had gotten smaller, was out of focus in the corner and the very middle, and the monitor smelled of burning. I'm typing on it right now and it seems to be getting worse, so I will have to get another CRT in a day or two.
So, what's the best CRT I can buy for under $125, $150 maximum? I want it to look good in games, have good contrast and black levels, and would prefer it to go up to 1600x1200 but I'm not sure if that's possible in my price range. The black levels and contrast are more important than resolution.
u could find a 19-21 in mitsubishi diamondtron for bout that much slighlty used.
try ebay
I decided to spend a little more and get this.
Seems like a good choice?
I don't know if a trinitron/diamondtron would be a better choice or not, I once had one but all I remember about it was that the two grey wires on the screen were kind of annoying.
EDIT-Hey, what about this? Would that be a better choice than the NEC?
EDIT2-Oops, just realized that NEC is Mitsubishi! :p
EDIT3-I went ahead and ordered the 19" NEC, the 22" on ebay won't fit on my desk.
