Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If I had $1,600 to spend on two E5-2640's or four AMD 6176's, which would you recommend? Or is $1,600 too much to spend on either set of CPUs? Should I be looking for better deals?
The idea was to create a dedicated 24x7 rig. Not too concerned about power usage. Mainly interested in really good TPF and/or PPD. I've read all the threads about running custom BIOS on the SuperMicro boards for AMD 61xx. Not sure which dual LGA 2011 is best for folding, but I imagine it's the Tyan board.
