Best CPU waterblock for direct die 9900K?
Kitsan
I was wondering if there are any waterblocks which are better for direct die custom loop cooling, perhaps that direct most of the water at the center of the block?
At the moment I have an XSPC Raystorm
Dan_D
[H]ard as it Gets
The EKWB Velocity is good, as is Heatkiller offerings. Those are probably a couple of your best options. Koolance Blocks are also pretty solid. I don't know how the XSPC Raystorm stacks up.
5150Joker
Honestly all blocks these days are within a few C of each other. If you're delidding, look for a delid bracket, one of those popular OC guys sells one but I can't remember what it's called atm.
newls1
[H]ardness Supreme
their "foundation" AM4 block is doing well on my 3950x. after having the heatkiller all copper IV and EK Velocity wb's, optimus did provide better temps. It was their mounting design that i wasnt found of (see thread at overclock.net) but block is stellar
Repo79
Optimus pc does great quality and they are USA based and that is a good reason to support them IMO.
