Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i know my Dell isn't ment for tweaking and thats fine, but whats the best benchmark to see if my P4 3.4 is performing as well as it should with in my systems limits.
For burn-ins and stability I use prime95 and memtest
For benchmarking (what I believe he is asking about), SiSoft Sandra and sometimes a little 3DMark03 or even Aquamark, while the latter 2 sill test the CPU somewhat, Sandra gives the numbers that are more easily comparable to other CPUs.
