DanK said:eVGA sells a drop-in replacement copper heatsink.
http://evga.com/products/moreinfo.asp?Part_Number=202-F1-EV18-01
aZn_plyR said:anyone uses one of those? how much drop did u get from the stock cooling?
aZn_plyR said:but then u would have to *cut* off the second pci slot cover and the nvsiliencer is only 1-3celsius better than the stock cooling so don't bother...
when does dell sell water cooled units??bmxbomb43 said:thanks alot for all the info guys. I always trust [H]ard forums to answer these questions. I am going to go with the artic S5. I am getting my ultra from dell so does nayone know if they come with stock fans on them? I think it might be a waterblock version.....
What is this "cutting off" you're talking about?aZn_plyR said:it is the best... for the gt's... it is better than the 6800ultra's stock.. but is it worth it to gain 1-3 celsius lower AND to cut off part of the dual pci slot on the ultra for so little gain? the answer is no unless u got money to waste and lots of time on ur hands.. if it was a gt.. then it would 100% be worth it if ur overclocking
