In a couple weeks I plan to build a whole new system.
I intend to buy:
Intel e4300 or e6300 core 2 duo
nvidia 8800 GTS or AMD HD 2900XT
2 gigs DDR2 800 ram (G.Skill)
and most likely a Gigabyte GA-965P-DS3 rev3
The case I have and will keep is a Thermaltake Armor VA8000BWS full tower case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133154
It has two 120mm fans and two 90mm fans.
My hope is to overclock the core 2 duo to 3ghz+.
To do so I'm going to buy a cheap aftermarket cooler.
I was hoping you guys could recommend one.
Right now I'm considering the Thermalright Ultra-90 (with some kind of a good fan) and the Arctic Cooling Freezer 7 Pro. UPDATE: Also under consideration is the Cooler Master Hyper Tx
Kind of leaning towards the Thermalright right now.
SVC.com is where I'm planning to order the cooler from. But if you know of a website that has the cooler cheaper then I'll certainly consider it.
I'm completely open to suggestions right now, I just want to keep the cost around $30 including shipping (I live in Florida).
If you recommend a cooler that does not come with a fan please also recommend a fan.
-Thanks
I intend to buy:
-Thanks
