Best Chipset for data throughput (HD performance)
willow
I will be running 7+ SATA drives (2 of them optical), & am interested in the best HD performance. (For file transfers, multimedia and backups.) I'm wondering if the X58 chipset is better than P55 for this. Also, since I will have more than 6 drives, what's the best secondary chip, Marvell's SATA3 or one of the JMicron solutions?
This will not be a gaming machine, so no SLI/Crossfire.
It is the southbridge chip that has the SATA controller. Both the X58 and P55 use the ICH10R. So I would think the performance should be roughly the same. And appears to be well ahead of what you'll find on AMD and Nvidia motherboards.
And I also think Marvell should be working better than the Jmicron as a secondary. Though if you are hooking up optical drives to the secondary, I don't think it'll really matter what you use.
Actually the P55 does NOT have the ICH10R, as it now handles the storage functions.
